Sponsored by: CARiD
No start condition - 2002 T/A
Old Jul 15, 2019 | 09:58 AM
joesurfer's Avatar
Default No start condition - 2002 T/A
This started as an intermittent situation that is now permanent. It won't turnover at all, battery is good, all lights on dash, just no crank, no clicking sounds at all. Few weeks ago it would start, then drive to the store and not start again until after several tries. Now not at all. Pulled starter and bench test but may not be the starter. Swapped ignition and starter relays, same result. Will check to see if power getting to starter signal wire next, ignition switch and maybe clutch safety switch but wanted to see if anyone on the board heard of something like this with 4th gens (maybe its a thing?).
thanks guys
Old Jul 15, 2019 | 02:17 PM
WhiteBird00's Avatar
Ungrounded Moderator
Is the SECURITY light in the instrument cluster on or flashing?
Old Jul 15, 2019 | 02:19 PM
joesurfer's Avatar
no, when I turn the key all lights come on as usual but did not notice a flashing security light. If that were the case, what would I check? (if you know).
thanks much
Old Jul 15, 2019 | 02:23 PM
A SECURITY light that remains on or flashes is the Vehicle Anti Theft System (VATS) preventing your car from cranking because it can't detect the correct key resistor pellet in the ignition. Flashing means it doesn't detect a resistor at all. On solid means it detects a resistor but not the correct one. That could be something as simple as cleaning the key (pencil eraser followed by alcohol) and the contacts inside the ignition cylinder (electronics cleaner and a pipe cleaner).
Old Jul 15, 2019 | 02:28 PM
joesurfer's Avatar
hey. worth a try for sure! thanks
Old Jul 19, 2019 | 03:07 PM
Blownbayou's Avatar
Check your ground to frame from the battery (main ground)....... Notorious for getting gunk on it.
Old Jul 19, 2019 | 03:17 PM
joesurfer's Avatar
thanks, I have been cleaning up connections as I go since I see a few places that were corroded. started with them first.
