Sponsored by: CARiD
Cut wire off PCM
Old Jul 18, 2019 | 09:04 AM
micbegz28's Avatar
Default Cut wire off PCM
Just picked up another fbody thats lived most of its last 6 years parked under a tree. Its a 99 Z28 6 speed car.
. while cleaning it up and getting it back to road worthy, i came across an issue.
As you can see, the light green/white wire is cut. PCM pin out tells me its "IAC Coil B High ControlPin B." That sounds important lol
I have not driven the car any more than out of a yard and onto a trailer, but it seems to run fine. Is this wire for something that is like a high RPM signal or something?
assuming i should just reconnect the wire and move on ?
Old Jul 18, 2019 | 11:32 AM
Stew2000's Avatar
Break out the soldering iron!
Old Jul 18, 2019 | 11:54 AM
LLLosingit's Avatar
x2, It obviously was hooked up before so it had of had some function.
Old Jul 19, 2019 | 07:12 AM
wssix99's Avatar
Save the manuals!
Looks like an animal was chewing on it. I'd look for others...
A properly sized heat shrink, waterproof butt splice (these days, found at any parts store) will get you back in order here:
Old Jul 19, 2019 | 09:27 AM
micbegz28's Avatar
deff planned on reconnecting. Kinda just lost on how it seems to not effect the car.
Old Jul 20, 2019 | 04:35 PM
wssix99's Avatar
Save the manuals!
You might check for codes. You could have a code for some sensor where the PCM is gracefully dealing with the failure.
