Sponsored by: CARiD
Water pump questions
Old Aug 4, 2019 | 05:35 PM
Majestic9C1's Avatar
Default Water pump questions
I am looking to replace my water pump real soon.. it doesnt leak but the pulley/bearing is making an awful gravelly noise...
I see that Rock Auto has 2 AC delco pumps but the price difference is about 100 bucks... what exactly is the difference??
Also is the Holley 22-100 pump a decent unit or should I stick with AC Delco?
Old Aug 5, 2019 | 07:22 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
This doesn't really answer your questions but,
Neither of those two Rockauto GM numbers 19195105 and 19256263 appears on the GM parts layout catalog. The GM catalog shows a 12458934.
In 2010 I replaced my pump on my 98Z with a Cardone remanufactured pump ordered from Summit and drop shipped from Cardone, has been trouble free so far.
Old Aug 5, 2019 | 07:00 PM
wssix99's Avatar
Save the manuals!
What did you do a few years ago??? https://ls1tech.com/forums/general-m...ater-pump.html
Have you been running with a noisy pump all this time? Is your pump now a failing replacement that you replaced back in 2014? If so, which one did you go with?
Here's another thread with some info. (You might try searching this site for more of those part numbers.) https://ls1tech.com/forums/cadillac-...-question.html
Old Aug 5, 2019 | 07:24 PM
nope still the same pump... I found out that noise was actually the idler pulley and not the water pump so I didnt change it... but now its the WP LOL
Old Aug 6, 2019 | 07:29 AM
wssix99's Avatar
Save the manuals!
This is because GM substituted the original pump for the LS2 pump. I have a link in Majestic9C1's original pump thread to a ACDelco Bulletin that explained the swap, with part numbers but they have since wiped it off the face of the internet...
I think the combo of your old link and the new link I posted and a search of the ACDelco parts site all correlate to the 252-846 having a heavier duty ("Professional") impeller. The 251-744 is the OE replacement and what I've had for years. Since GM uses these ACDelco parts, you may also find different GM vs. ACDelco pricing for the same part. (Gotta love that! - actually not.)
I don't know anything about Holley's pump, but I do think this is a perfect situation to dance-with-who-you-came-with. The GM/ACDelco part has lasted 2 decades! I expect the only direction your performance and longevity can go from there, if you switch, is down...
Old Aug 6, 2019 | 03:29 PM
right on.. I'll stick with AC Delco thanks
