Sponsored by: CARiD
Car won’t start sometimes.
Old Oct 10, 2019 | 11:18 AM
whitebird95's Avatar
Default Car won’t start sometimes.
I have a 2002 Trans Am and it’s starting to not start sometimes. The VATS is already bypassed with resistors and there is no security light on. When I turn the key the car does nothing but I can hear something clicking in engine bay. I have found that if I keep turning the key, the car eventually cranks and fires up. Any ideals?
Old Oct 10, 2019 | 05:34 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Have you checked your battery terminals yet?
Old Oct 10, 2019 | 06:49 PM
Not yet. That was actually the next thing I was going to check. The car is at my parents house so I can’t check them at moment. This problem just appeared out the blue and the car only has 62k miles on it so I was hoping it’s something simple.
Old Oct 11, 2019 | 07:28 AM
wssix99's Avatar
Save the manuals!
This is the time of year where this happens on cold mornings, etc.
Is this related to temperature? If so, you could just have a bad/old battery.
Old Oct 14, 2019 | 03:05 AM
Don’t think it’s temperature related since it happens on hot and cold days. It honestly seems to be random. I got in the car over the weekend and it started fine but sometimes it just does nothing.
Old Oct 14, 2019 | 07:03 AM
B52bombardier1's Avatar
My 70 El Camino had a similar problem when I had the PCM wired incorrectly when I first did my engine swap. I did not have permanent (as in ignition key does not matter) 12 volt "keep alive" power to the PCM memory wire. At least for my "896" and "411" PCM's, they have keep alive power wires and boot up / operating power wires. Without 12 volts to the memory keep alive wires, the PCM has forgotten its learned parameters which makes initial starting difficult.
But it will eventually start . . . 4-5 difficult ignition key turns later. Stumble, cough, cough, slow idle, cough . . . . . and finally, settles out.
Rick
Old Nov 19, 2019 | 08:25 PM
LETZRIDE's Avatar
Have you looked into it being a BCM issue? The 4th gens are known to have a BCM issue and all 3 of my Fbodies have gone through this. You symptoms may not be the exact same as I have in the video here. Some may be present or none at all. Each of my 3 F-bodies had one thing in common when it went. The car began to have intermittent starting issues.
Take a look at this F-body BCM repair guide - the bcm is easy to pop out and you can either solder it yourself if you are handy, or whip it over to an electronics place and they will touch it up for pretty cheap.
My guess is this is going to fix your issue 9 times out of 10
