Sponsored by: CARiD
Need help finding window guide parts
Old Jan 20, 2020 | 04:52 PM
demonsmokr's Avatar
Default Need help finding window guide parts
Trying to load pictures, but keeps having issue processing data?
Anyways, the roller on the guide bracket is fucked. Almost pulling completely out, and thats thats causing my window to not line up properly going up. I mistakenly thought it was the regulator, and bought kits for both sides. Regulator is aging, and needed replacing anyways.
BUT, its not the main problem on drivers side. Passenger side is good, but driver is fudged.
Im browsing Hawks,but not seeing parts. Im not buying a whole ******* door.... unless i really have too.
Anyone have any ideas? How could i find a bolt in roller? If i i could get this out, might be able to drill and tap it. But if someone has rigged something up before, spill the beans please!
Old Jan 21, 2020 | 04:55 AM
Nathan C's Avatar
I bought mine from Ecklers
Old Jan 21, 2020 | 06:47 AM
wssix99's Avatar
Save the manuals!
Is this your problem? https://ls1tech.com/forums/general-m...dow-guide.html
Old Jan 22, 2020 | 05:46 PM
demonsmokr's Avatar
Originally Posted by wssix99
Thats exactly it. I wasnt searching correctly, I was searching "roller shaft" and coming up with nothing related, to say the least...
But, Ive attempted a fix. Lost light last night, been raining all day today and probably tomorrow too. But, i drilled and tapped the roller itself. 6-32, with a, 1/8" flat washer on back, and Im going to loctite it so it should stay. We will see....
Old Jan 22, 2020 | 05:49 PM
demonsmokr's Avatar
did you get the whole guide channel, or just the roller guide pin thinginmajig?
