Z28 replacement key not working
Did they look up the original codes for you or did they just make a mirror image of your other worn key?
If the key will not turn, there would be a mechanical problem with the key/cylinder. (Either a bad key cut, a worn key, or a bad cylinder.)
... or this also happens when the steering lock is tight. Its always a good idea to try turning the steering wheel a bit to see if that solves this problem.
