Traction Control and ABS Lights
So I was troubleshooting a noise I've been having in the rear end and I had the rear end in the air. I put it in drive to get the tires to spin to see if the noise would occur. I realized I didn't turn off traction control like 5 seconds in so I switched it off. I just tried turning the traction control back on and it won't... I also have ABS INOP light. Any ideas what I may have done?
If you have a scanner that gets into the ABS system, you should be able to manually clear and reset the codes.
