Sponsored by: CARiD
Vss issue ?
Old Apr 2, 2020 | 08:21 AM
ARbirdguy87's Avatar
Default Vss issue ?
Hey guys , I've got a 97 formula firebird and my speedo is wayyyy off . At 50 mph I'm showing 80 or 90 mph . Since the speedo is controlled by the computer via communication with the vss , is this likely the culprit ? The po said the instrument cluster had been changed prior to his ownership and I believe it is correct for the car . Possibly from a v6 car and if so is the stepper motor different in that cluster ? I'd imagine since its controlled by the pulses from the vss it shouldn't matter but I could be wrong .
Old May 4, 2020 | 06:15 PM
Supercharged111's Avatar
Hopefully you get an answer. I just put a cluster into my 93 and the speedo buries itself as soon as I start moving. I have a VSS in my spare trans to try.
Old May 6, 2020 | 05:19 PM
I just changed VSS and that wasn't it.
How high does your speedo read? Should be 150 for a V8 and around 120 for a V6.
