Sponsored by: CARiD
Mirrors Brezel
Old May 14, 2020 | 06:17 AM
Volcente's Avatar
Default Mirrors Brezel
Hallo!
It is normal these cracks on the interior mirror brezel?
I've fix it with Attack but I need to know if is a common issue.
If it is a common issue better to fix it than change the part.
many thanks!
Old May 14, 2020 | 02:53 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
At least one of mine has cracked, so this is not unheard of.
Old May 14, 2020 | 04:29 PM
JOHNNY59's Avatar
Very common!
Old May 16, 2020 | 10:01 AM
wssix99's Avatar
Save the manuals!
You'll see that the part has "ABS" stamped in it because it is ABS plastic. You can get some ABS cement from a home supply store. (Be sure to get pure ABS cement and NOT a multi-purpose cement.) The pure ABS cement will chemically weld the plastic back and should make the part almost as strong as new. (Just be sure you don't put so much on that those pins won't fit in their holes.)
Here's the stuff we have in the States:
