Cam Sensor Wiring Issue now Computer Issue?
Edit: The day after rewiring a new connector for the cam sensor the car started running extremely hard. Just about every sensor code started triggering. White smoke from fuel started pouring out the back of the exhaust. The fuel injectors on the drivers side starting staying open constantly. I assume that this is the cause of a bad ecm and I bought a new one. Why would fixing the cam sensor wiring break the computer?
^ Or you can search Youtube for P0342
These codes can be made from a number of causes, but you'll want to check the wire references first.
