02 4.8 silverado surging??
Threw both knock sensor codes today
trans does not feel like it is slipping at all as there is no rpms flare while driving it. Hoping if worse case it may be the tcc soleniod as that does not look to hard to replace. I just do not think that it just went out though.
Idle bounces from 550 down to around 430 in drive sitting still. Not as bad in park but it is noticeable.
tcc slip rpm.
In high gear when it starts to surge the tcc rpm is around 1-5 varying. when you step on it and you can feel it down shift and the tcc rpm goes up to 330-400.
From what I saw fuel pressure is around 52 ish driving even during the surging but when you let off the accelerator it drops to 42. I am going to be swapping the cats tomorrow as I have been fighting the back 2 bolts on the back of the y as there started to spin in the pipe. Just go those out.
any help?
missfire video
fuel pressure at idle
tcc rpm slip video
fuel presure while driving video
idle video (in park to drive back to park)
I think that the small surge I see is from the injectors. Have not been able to find a trustworthy place for replacements or cleaning.
