Emissions Issue on a `99 Suburban
I may have to cut my losses and sell it super cheap to someone aware of the codes.
The 430 code is for catalyst efficiency. Could be a bad O2 sensor or your catalytic converter is worn out. Or both. I had no idea that Georgia was an emissions testing state.
Rick
But I'm still confused about how your birthday ties into all this. Is your driver's license also expired, and is that somehow tied to e-testing in your state? Many years ago, something similar used to be true in my state (lack of e-test compliance would lead to a suspended DL), but they stopped doing that long ago and now you simply can't renew your plates until the test is complete or a wavier is obtained. Lack of emissions compliance no longer has any impact on DL status here. But if this IS regarding your driver's license rather than just the vehicle plates, then you could simply have a shop do the repairs and complete the drive cycle, after which you could get it towed to the e-test center (or, have someone else with a valid DL drive the car after you make repairs).
I'm retired and worked at a Tuffy automotive repair facility part time in the mornings. I was the drive cycle person. Slap on the plate and drive it, come back and read codes, others would do the repair and I would drive cycle again. When everything was OK I would drive it to the testing facility to obtain the 'pass' documentation for the owner to be able to get registration. Worst case I ever had was a Ford Escort that took over a dozen drive cycles to set the monitors to OK/ready.
Anyway, as FirstYrLS1Z mentioned above, if all else fails and you can't get some sort of waiver yourself, just get a shop involved. They will be able to drive the vehicle and/or obtain whatever permission is necessary to do so in your state because this is the only possible way that it could be prepared for testing.
