No crank
Moving on. You can hear the fuel pump working, good. Can you also hear the Bendix gear engage the flywheel from the starter? You should probably hear that click in even with a battery that does not have enough power to turn the engine over. No rrrr,rrrr like a weak charge even trying to turn over?
Be sure of the battery. Be sure of the connections to the starter. Then you should get something to happen.
The neutral safety switch is the one under the clutch pedal in your manual car, right? They do go out. Good battery, good connection to starter, no reaction from starter, I would look at that switch.
