Sponsored by: CARiD
PCM replacement relearn necessary?
Old Oct 9, 2020 | 02:44 PM
Elthesh's Avatar
Default PCM replacement relearn necessary?
If I'm replacing the pcm in a 99 with a replacement I ordered that has already been programmed with my vin, do I need to do any kind of key relearn? Not certain since I keep reading people swapping pcms in and out and the car just runs.
Old Oct 9, 2020 | 02:51 PM
WhiteBird00's Avatar
Ungrounded Moderator
The key relearn you're thinking of is for the BCM not the PCM. It's part of the VATS security. A new BCM will automatically match to the first key used but can't be reprogrammed after that so a used BCM is a completely different can of worms. But your PCM doesn't require any key matching at all.
Old Oct 9, 2020 | 02:54 PM
Elthesh's Avatar
Thanks. That's what I figured. So plug and go, excellent.
