Sponsored by: CARiD
No high beams
Old Dec 31, 2020 | 04:18 PM
vince72's Avatar
Default No high beams
Guys,
Anyone have a diagrams of the column parts needed to make the high beams work? I am having issues and I am not sure what it is, ie lever(everything else for the lever works), column parts, or electrical parts for it?
Any pointers appreciated.
Vince
Old Jan 1, 2021 | 09:10 AM
zzracer's Avatar
Good chance it's your switch down on the column. The rod running down the column goes into it. Little bit of a pain to get too. Unbolt the column from the dash and let it fall down some and it makes it easier.
Old Jan 1, 2021 | 10:45 AM
wssix99's Avatar
Save the manuals!
Please post details on your car. For things like headlights, it makes a big difference. (Camaro vs. Firebird vs. Corvette)
I recall that you have a Camaro, so that would take a lot of common issues off the table that afflict the flip up bulbs. I also recall you are working on your steering column. When did your issues start? (If during that job, then zzracer has the first thing to check. There are also details of this mechanism in the Jazzman guide that we linked to in the other steering column threads.)
Old Jan 1, 2021 | 12:20 PM
vince72's Avatar
I have a 96 z28 camaro I bought two month ago and the high beams never worked. I pull the lever and I dont even hear a click, but I can turn them on by pulling the rod. I am not sure if there are any broken internals ? The turn signals work, hazards & wipers. I do notice that the lever does not return back to its original position if I pull it towards me.
Old Jan 1, 2021 | 02:16 PM
zzracer's Avatar
Not hearing it click is one more reason to check the switch on the column.
Old Jan 1, 2021 | 07:33 PM
vince72's Avatar
By switch do you mean the lever?
Old Jan 1, 2021 | 07:57 PM
zzracer's Avatar
No, there is a rod running down the column into a switch. When you move the arm it pushes the rod into the switch to actuate the switch. The switch is probably broken but I have seen them loose and slide away from the rod enough that it won't work. I would check that first.
Old Jan 1, 2021 | 09:14 PM
vince72's Avatar
Is it the white switch at the bottom?
Old Jan 1, 2021 | 10:19 PM
zzracer's Avatar
Yes ,bottom of the rod.
Old Jan 2, 2021 | 12:31 AM
vince72's Avatar
Thank you
Old Jan 3, 2021 | 09:28 AM
wssix99's Avatar
Save the manuals!
Here's the document with all the details on the internals of the column: http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
I'd check to see if your high beam follower or other pieces there got out of place when you did the tilt pin fix.
Old Jan 3, 2021 | 09:49 AM
vince72's Avatar
It might be the follower, I hope they seek this piece separate. It looks like Im going to have to take most of it all apart again...
