Sponsored by: CARiD
Driver's side window issue
Old Jan 20, 2021 | 01:02 PM
Roarin_8's Avatar
Default Driver's side window issue
Video speaks for itself. Window motor was replaced on it. After several months, when the window was down, there was a bang inside the door and now it's been doing this ever since. Any ideas on how to fix?
Old Jan 20, 2021 | 02:04 PM
Roarin_8's Avatar
Found the problem, the replacement window motor is bad. It's the one doing the hesistation instead of spinning smoothly. Now I'll have to get 2 since the passenger one is on it's way out.
Old Jan 20, 2021 | 11:35 PM
dannyual777's Avatar
From: Montgomery (Lake Conroe,) TX north of Houston
I'm glad you found out what was causing all of that hesitation and noise.
I'm interested in these window motor threads because my WS6 needs it's driver's side window motor replaced. I've been putting it off for at least 2 years.
Old Jan 21, 2021 | 06:26 AM
Roarin_8's Avatar
Thanks. I put it off for awhile too and finally just dove in yesterday. Ordered a new set today. It's not too bad installing the hardware with a phillips and socket.
Old Jan 21, 2021 | 04:15 PM
wssix99's Avatar
Save the manuals!
Did you adjust the felt stabilizers at the top of the door? If not - good. If so, they could be making this problem worse.
When properly adjusted, those stabilizers will not touch the glass for the full travel of the window.
Old Jan 21, 2021 | 06:48 PM
Roarin_8's Avatar
Nope, nothing else on the door was touched.
