Sponsored by: CARiD
HVAC blend knob regularly cracks inside
Old Feb 14, 2021 | 10:05 PM
JimMueller's Avatar
Default HVAC blend **** regularly cracks inside
Every year or so my HVAC blend **** cracks on the inside. The metal D-ring inside the clear tube appears to rotate, which causes the clear plastic tube to crack and flex, which in turns causes the **** to not work well. I've band aided this in the past with replacement *****, but I'm wondering if there's something else besides the **** in play here. What else could be causing this behavior other than poor **** quality?
Old Feb 15, 2021 | 08:08 AM
wssix99's Avatar
Save the manuals!
You just have to be calm before you turn the ****.
The only other thing I can think of is if your ***** are all used or if they are getting full/constant sunlight.
Old Feb 15, 2021 | 08:38 AM
VIP1's Avatar
Copy & Paste Moderator
Either you are twisting too hard or the mechanism has gotten so stiff that you are needing to twist too hard. Its all mechanical cable driven. I guess you need to look for things to lube.
Old Feb 15, 2021 | 11:13 AM
JimMueller's Avatar
Even when I replace the **** it's still stiff to turn slowly compared to the other two *****. I vaguely remember that the HVAC controls are dependent upon vacuum. Could low vacuum, a vacuum leak, or not having my vacuum tank connected (broken line that was capped at the distribution point) be related?
Old Feb 15, 2021 | 06:40 PM
VIP1's Avatar
Yes to all the above. Fix what is broken. Its a combination of cable and vacuum. The center **** will be stiffer than the other two, but not stiff enough for you to be breaking *****. If the vacuum wasn't working at all then you wouldn't be able to chose where the air goes let alone the temperature.
Old Feb 15, 2021 | 09:22 PM
98ws6blk's Avatar
It's just a factory factory flaw... I think I've replaced all of them at some point. I don't know any real fix.
Old Feb 16, 2021 | 02:42 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
None of mine have ever broken, but if the interior sees a lot of heat/sun then brittleness and fatigue might just be a recurring issue. It should not be super hard to turn any of the *****, though the blend **** does seem to always have more resistance than one might expect (as compared to some other applications).
Old Feb 16, 2021 | 05:36 PM
wssix99's Avatar
Save the manuals!
The temperature blend ****, as pointed out above, is cable-controlled and just operates a simple flapper/door in the duct system. (Right above the passenger's feet.)
The FSM says to detach the cable from that duct (one bolt) and then test the ****. If it binds or is hard to move, replace the cable. (The FSM implies that it's non-serviceable.)
As you remove the cable from the door, be careful. There is a round housing that engages the shaft for the flapper/door and there is an adjusting spring and other parts in there that you don't want to let loose.
Old Feb 26, 2021 | 10:23 AM
JimMueller's Avatar
The car has been parked outside practically all of its life, at home in the shade, elsewhere I use a windshield heat screen if I feel its warranted that day. I received a handful of used replacement ***** and a pair of used replacement cables. Regarding vacuum, I have been unable to find an exact replacement for the hose connection between the vacuum check valve and the vacuum tank in over a year. I cobbled something together but I couldn't get it back into the harness that goes over the shock tower so I didn't install it. I'll dig into it this weekend, I appreciate the help fellas.
Old Mar 6, 2021 | 11:59 AM
jhunter618's Avatar
I'm wondering if it's the heat from the bulbs that is causing the plastic to become brittle. I've had to replace the ***** every couple of years. I have an 02 WS6 and it is kept either in the garage or under the carport, granted I do live in Fla. so I don't move the ***** much, they basically stay on A/C most of the time.
Old Mar 6, 2021 | 05:59 PM
RPM WS6's Avatar
I don't think it's bulb heat specifically because the problem only seems to be a common occurrence for those folks from FL or other very hot places. I don't think anyone up north has reported this as a frequent/recurring problem, even on high mileage cars. So ambient conditions (variable) likely play a bigger role than heat from the bulbs (fixed).
Old Mar 9, 2021 | 07:06 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Smile
Sara (2001 Z28) and I live in a warm climate, and her ***** are just beautiful, soft and supple to the touch.
Old Mar 9, 2021 | 04:59 PM
LS1121's Avatar
Dude you got issues.
Old Mar 11, 2021 | 07:54 AM
SMACarthur's Avatar
Lol,
can you repeat it in Firebird 1999
Old Mar 11, 2021 | 08:13 AM
SteveC's Avatar
Smile
Yes I have, I have been seeing a Ford therapist for this. He says "there's no hope for me".
Old Mar 11, 2021 | 08:36 PM
LS1121's Avatar
Seems like corvette therapy is needed here.
