Sponsored by: CARiD
Finally decided to fix up the AC
Old Feb 22, 2021 | 10:11 AM
Ape Man's Avatar
Default Finally decided to fix up the AC
Thought I'd take the winter and finally fix the leaking AC compressor (leaking at body since I got the car)
Found :
-Compressor leaking
-Rubber line to condenser leaking
-Condenser not looking too hot
Replaced :
Delphi Compressor
Delco Condenser
Accumulator
Orfice tube
Delco Discharge and Suction hose set
Delco PSI switch
New AC belt tensioner, idler and belt
Once its warmer Ill take it to where I work to do a nice long vacuum and recharge and be good to go!
Old Aug 5, 2021 | 08:46 PM
Spankstangs1999's Avatar
How much was everything if you remember. This project is next.
