Sponsored by: CARiD
Battery/ Voltage Short
Old Mar 17, 2021 | 12:37 PM
Ouu Benny's Avatar
Default Battery/ Voltage Short
Okay, i bought a new battery 2 months ago & drove it for a week, shows its dead. Got it recharged & replaced the ground wire & still dies within a week to 2-3. So i got the battery swapped & had it for like 3 weeks & still died. I got the alternator checked & shows it runs good. Please help. GM
Old Mar 17, 2021 | 08:07 PM
B52bombardier1's Avatar
What vehicle? What year?
Rick
Old Mar 17, 2021 | 10:46 PM
Ouu Benny's Avatar
Rick
Its 99 silverado but motor is swapped w/ a 03 suburban 6.0.
Old Mar 18, 2021 | 07:52 PM
Those GM trucks have a problem with the instrument cluster not going to sleep after the engine is shutdown. Pull the fuse for the instrument cluster and see if your problem is solved. Then send your cluster off for a repair.
Rick
Old Mar 21, 2021 | 08:07 AM
dannyual777's Avatar
From: Montgomery (Lake Conroe,) TX north of Houston
Rick
It's pretty much impossible to fix a problem if you can't identify the problem. What Rick is suggesting is a great idea to see if the instrument cluster (known problems) is indeed the problem. Once identified, then you can fix it or have it fixed. Let us know how it goes with the fuse pulled.
