Stripped PCM bracket bolt. Please help
also, the tuner said I should run a tap into the pcm to clean it up. Does anyone know what size of tap to use?
any help or suggestions are really appreciated!
That almost looks like aluminum is stuck in the threads. Might be able to get it out with a knife and it would be fine. I'd be more concerned with the PCM threads.
