Sponsored by: CARiD
Problem installing a starter and engine mount
Old Jun 25, 2021 | 04:54 PM
Vslims's Avatar
Default Problem installing a starter and engine mount
I have a 1990 Chrysler Le Baron 3.0L 6cyl. I replaced the oil pan gasket, reinstalled it as I attempted to reinstall the starter and the front lower engine mount I not able to line up the bolt holes on the engine mount bracket which also has a extented arm on the bracket that has to reach back to a bolt that attaches that bracket to the bottom section of the transmission below the flywheel. The engine is sitting too far back to line up. I loosened the top right engine mount bolts to give some play on the block but isnt moving forward enough. There about 1inch and 1/4 gap. What should I do?
Old Jun 25, 2021 | 07:54 PM
wannafbody's Avatar
Wrong forum
