Sponsored by: CARiD
Security help!!!!
Old Jul 24, 2021 | 05:00 PM
Gables's Avatar
Default Security help!!!!
98 Pontiac firebird, security light is flashing and won't allow me to start the car, I've tried using the key in the door, and the hatch, I've unplugged everything and let it sit for a while.... Nothing seems to be working, am I missing something? Please advise. Thank you in advance.
Old Jul 24, 2021 | 06:19 PM
Nathan C's Avatar
VATS is bad. You need to replace the ignition cylinder lock.
Old Jul 26, 2021 | 02:07 PM
WhiteBird00's Avatar
Ungrounded Moderator
VATS indicates a problem in two ways... a steady on security light means that there is a resistance reading seen from the key but it's not the correct one; a flashing light means that no resistance is seen at all (an open circuit, actually infinite resistance). This can be caused by the wires breaking at the ignition cylinder but it can also be a break in the sensor wires anywhere between the ignition cylinder and the BCM (which houses VATS). If you've been doing any work under the dash, check that the 2-wire connector with the white wires in the orange sheathing is plugged in tightly to the connector at the base of the steering column. If you have a VATS bypass installed, check that the resistors haven't come apart.
