Fans not running
Or, I run two Four Seasons part number 35879 fan relay / fuse / adjustable thermostat kits. One kit for each of my fans with their own power supply, ground, relay and fuse for best cooling safety and redundancy. These kits also have support for a fan when needed as the AC compressor turns on. They also kick on a seven inch fan for my transmission cooler. I have a third one of these kits that kicks on a seven inch pusher fan in front of my AC condenser that yields me another six degrees F of colder air at the center vent - now a measured 34 degree F air going down the road using a meat thermometer stuck into the AC vent. Can you tell that I'm a believer in these fan relay kits? The only problem I've had with them was trying to make one relay kit support two big radiator fans that each eat a lot of amps - the fuse holder got a little hot until I split my fan operation into two relay assemblies.
https://www.summitracing.com/parts/f...xoCZmUQAvD_BwE
Rick
