Alternator upgrade help!!
340 is a lot of alternator... Welder or whooping big stereo?
The Alternator vendor should be the best source of info. There are a couple different option depending on engine year/origin etc.
Rick
So no, installing a huge alternator, by itself, will not cause any damage to your electrical system. But, as B52bombardier1 alluded, adding accessories which draw more current can overwhelm the factory wiring so you must ensure that you connect any high power accessories you install with large enough wire to handle the current draw. Also, make sure you install the appropriate size fuse in the circuit as close to the power source as possible. Remember, fuses are there to protect the wiring not the accessory... you want a fuse to blow before the current flow gets high enough to heat up the wire and possibly cause a fire.
