To drain plug, or not to drain plug...
What're your guys thoughts on changing filters, fluids, pans with plugs, etc? Seems like an unnecessary expense to me. Thanks in advance...
Automatic transmission fluid changes for TH400, 700R4 & 4L60E, have always dropped the pan to dump the fluid, no drain plug. New filter & gasket, clean magnets etc refill to proper level.
Since that only gets part of the old fluid out as some remains in torque converter, I tend to do the transmission fluid & filter more often. Typically ~15,000 miles. Fresh clean transmission fluid is critical for longevity for sure.
No experience with the newer transmissions.
Also, fluid changes become so easy with a drain plug that you can refresh the fluid more often than would otherwise be feasible due to the extended process of dropping the pan, being careful not to spill the fluid as mentioned above, swapping out the filter, and then re-torquing the pan properly to prevent leaks. That all takes a lot more time than a simple plug pull and fluid drain/refill - so the practicality of more frequent fluid changes (compared to what would be a typical interval when the time is required for the longer filter change process) does offer some benefits.
On the downside, most of the aftermarket plug kits tend to leak in my experience. Never a ton, just a drip or two here and there. The exception to this was the nice 4L60E truck pan that GM used to sell many years ago - it was deeper and had a factory drain plug built in. The plug and seal was of the same quality as a factory engine oil drain plug, and it never leaked. I put one on my Trans Am, but when I went to buy another several years later GM had changed the design of that pan and removed the factory plug.
I found a much better plug at Autozone (Needa 653076) for $4 that has a much beefier head but just a tad long (M12-1.75). I zipped the extra length off with a cutoff wheel and used the OEM plugs gasket as it was larger in diameter and fit perfect. No more worries with rounding off the soft GM drain plug and zero leaks.
My struggle with that dam OEM plug
Attachment 712391
Attachment 712392
Attachment 712394
