Sponsored by: CARiD
Hard cold start and dying at stops
Old Feb 12, 2022 | 07:14 PM
Ls2bird98's Avatar
Default Hard cold start and dying at stops
Hello,
I have a 2001 Firebird with a built ls2 and I’m having problems with the cold start and dying at stops when driving. The hvac vacuum line was not hooked up when I bought the vehicle so when I got it home and plugged it in I started having these issues, unplugged it and issues went away. I went had a tune on it and it seems the motor was tuned to speed density and is not running boost nor has a mass airflow sensor. The guy that tuned it recommended a new throttle body as it had a cheap Holley knock off in it with new Iac and tps. I replaced with a Nick Williams tb and new sensors. The problem consists. Any ideas?
Old Feb 22, 2022 | 07:13 PM
FormulaBoat's Avatar
Sounds like there is a major air leak in the HVAC system, and previous owner knew it. Put a hand vacuum pump on it to confirm.
Old Feb 22, 2022 | 09:31 PM
theunderlord's Avatar
You have a leak somewhere, I'd start tracing lines and checking their integrity.
Old Feb 28, 2022 | 07:51 PM
Ls2bird98's Avatar
I put vacuum to the line from the intake to all the hvac lines and nothing, all holding vacuum.
Old Mar 1, 2022 | 06:12 PM
Ls2bird98's Avatar
also, scan tool reads 20inhg off the map sensor off idle.
Old Mar 1, 2022 | 08:13 PM
Ls2bird98's Avatar
Default Hard cold starts, stalling at starts
Hello,
I have a 2001 Firebird with a built ls2 and I’m having problems with the cold start and dying at stops when driving. The hvac vacuum line was not hooked up when I bought the vehicle so when I got it home and plugged it in I started having these issues, unplugged it and issues went away. I went had a tune on it and it seems the motor was tuned to speed density and is not running boost nor has a mass airflow sensor. The guy that tuned it recommended a new throttle body as it had a cheap Holley knock off in it with new Iac and tps. I replaced with a Nick Williams tb and new sensors. The problem consists. Checked vacuum, everything looks good. Any ideas?
Old Mar 1, 2022 | 08:54 PM
jetech's Avatar
Veteran: Air Force
Why not use a factory LS2 throttle body and maf and then get it tuned?
