First part to remove the window regulator and motor
I'm new to the forum so hello to all of you!
I seek the first part to remove the window regulator and motor for a 4th gen. I can not download it from this website. The second part is no problemo.
This is the link to the first part : http://www.firebirdnation.com/pdf/windowreplacement.pdf
But the link don't work...
Anywhone?
Thanks in advance!
Kenneth
If you need to replace the motor, the best method is the shbox method. http://shbox.com/page/windowmotor.html
There are lots of posts on this site detailing why and other details around this. Removing the regulator is very complicated and can do long-term damage to the door. It also requires special rivets and special tools to install. The regulator can NOT be re-installed with bolts due to the composite the door is made out of.
