Window Scuffing and Door Panel Cracking
The tint on my driver window is scuffed and the panel is cracking right under it. I did the repair on the panel but the crack continues to grow. I just noticed recently that the tint is scuffed right above the crack. The pic isn't very good, but you can see the crack and how the window isn't clear right above it.
Any ideas as to what would cause this? I could move the window stabilizer out, but it seems that would just increase the pressure on the window. Otherwise, the window is aligned perfectly and works flawlessly.
I haven't pulled the door panel yet - just got finished replacing the window motor on the other door - but will soon. Any suggestions as to what to look for would be appreciated.
But when I pushed the rear stabilizer out to where it kept the window firm, the window didn't fully roll up in the front. So I adjusted it to where all was good. But as I said, the window still feels loose in the rear. Regulator problem?
I've seen members scratching tint when they got a stone or other abrasive caught in the stabilizer. You might take a look at them and comb the felt to make sure yours are clean.
