Sponsored by: CARiD
2002 OBDII codes
Old Dec 7, 2022 | 04:09 PM
johnfin1's Avatar
Default 2002 OBDII codes
So I am getting P0300 (random misfire)and P0332 (knock sensor) but the car runs smooth and strong. Anyone else have this issue?
Old Dec 7, 2022 | 04:23 PM
strutaeng's Avatar
What vehicle and engine?
You probably have an intermittent misfire and haven't noticed it. You need to hookup a scanner that has misfire counts to see what cylinde(s) are missing.
Same thing with the knock sensor code. I think that one will cause the ECU to pull timing a bit or something if it detects knocking. There's a way to check the knock sensors with dvom and striking the engine block with a large screwdriver and hammer. I found a video and it to my truck a while back. Either knock sensors and/or wiring harness are usually the problem.
Old Dec 7, 2022 | 05:17 PM
ghardester's Avatar
johnfin1, you have previous posts about the same issue of random misfires. One mentions the misfire being on cylinder #4, did you change the plugs, the coil, and check out the fuel injector on #4? Because most of these kind of misfire codes will lead you back to: New plugs, new wires, and changing or moving the coil to try to determine if it is faulty. Your knock sensor code is likely a result of the computer trying of compensate for not running on all cylinders all the time.
Old Dec 7, 2022 | 06:43 PM
johnfin1's Avatar
Yea, it was #3 but now it just general. Car runs and performs perfect. I have an actron CP9580 which does a ton of checks, dynamic too, but I dont see any feature for individual firing check. Is there a cheap scan tool that can do that? What about a strobe light?
Old Dec 8, 2022 | 04:52 PM
johnfin1's Avatar
Default Fuel
Iam convinced tge problem is poor or contaminated fuel. Cleared codes and when i punched the gas pedal it pinged and i got the knock sensor code.
