Sponsored by: CARiD
dielectric grease
Old Feb 1, 2023 | 07:37 PM
Camaro223's Avatar
Default dielectric grease
Anyone use dielectric grease on connections like PCM plugs? Or is it best to leave them dry?
Old Feb 1, 2023 | 08:02 PM
wannafbody's Avatar
Super Lube is great. You can find it at Harbor Fright
Old Feb 2, 2023 | 06:47 AM
WhiteBird00's Avatar
Ungrounded Moderator
Harbor Fright? Is that one of those pop-up Halloween stores?
Dielectric grease can be used in any connection that is exposed to the elements. It is not always necessary depending on the connector design (i.e. connectors that are already weatherproof without dielectric grease) but it won't hurt anything.
Old Feb 3, 2023 | 12:17 AM
wssix99's Avatar
Save the manuals!
There is a GM Technical Service Bulletin for the PCM connector. Whenever it is removed, the seal is supposed to be replaced to handle water intrusion: https://ls1tech.com/forums/general-m...onnectors.html
No grease should be necessary.
