Sponsored by: CARiD
Ignition delay before car starts
Old Feb 14, 2023 | 07:32 PM
Josh higbee's Avatar
Default Ignition delay before car starts
So I just swapped a steering column into my 99 camaro. I took my good ignition out of the old column and put it in the new one. Now when I go to turn the car on there's about a 3-5 second delay before the car turns on. In that delay you hear no relays, no starter, nothing, and all the interior lights as well as radio stay on. When the car decides to turn on it cranks very quickly. Also no security light either. I'm thinking possibly bad ignition switch on top of the column? I know for a fact the ignition cylinder is good as its a newer gm one and it ran in my other column with no issues. Worth noting this is an automatic car.
Old Feb 18, 2023 | 02:50 PM
wannafbody's Avatar
Try changing the ignition relay and see if it makes a difference. I doubt it fixes it but it's a cheap thing to test. Was the column from the same year car? Maybe there's some incompatibility.
