Sponsored by: CARiD
Coolant drain
Old May 1, 2023 | 06:19 PM
WebKruzer's Avatar
Default Coolant drain
Hi guys, I have 2003 5.3 and I want to flush out the old coolant in the block, but I can't get the block drain plug out in the left rear, I don't want to break anything. Is there another way I can blow it out or something. Any help would be appreciated.
Old May 1, 2023 | 07:59 PM
4thGenCamaroZ28's Avatar
I usually use a clean shop vac to remove coolant.
A thin wall 3/8 ID hose goes into the block nice with the water pump off, just tape it to the shop vac hose.
Old May 2, 2023 | 10:45 AM
WebKruzer's Avatar
Thank you I'll give it a try.
