Rattle after trans mount replacement
At the same time I replaced the mount, I also replaced both ujoints. I've checked everything out, it all seems tight.
Is there any chance when I put the drive shaft back in the yoke would... Grind on the part that slides into the transmission?
Could the exhaust be tapping on something after the mount replacement?
Car runs strong and does NOT make the noise in park.
I can probably post a video of the rattle.
Its interesting how the sounds can be so many different things. It doesn't grind while in park, so its hard to get out and see exactly where its rubbing while making the noise.
Thank you both for your feedback, fingers crossed all it is, is the exhaust rubbing!
