Headlight Motors
There is a mega-thread in the Firebird-specific forum all about headlight doors. You'll find it in the stickys. This is going to be your best place for information. https://ls1tech.com/forums/pontiac-f...-1967-2002-73/
The brass gear thing is not a good fix. They strip just like the plastic gears and (IMO) are a waste of money. If you have a bad motor, it will just rip apart your metal gears like it did the plastic ones: https://ls1tech.com/forums/wiring-st...ght-doors.html
If the gears are good, check out post #1838 in the mega thread and start reading from there. The solder on the headlight module is a common issue and can affect the sides differently.
However, if you pulled out broken plastic gears - your problem is likely mechanical.
