Sponsored by: CARiD
Automatic with a very specific issue with stalling
Old Mar 7, 2024 | 03:19 PM
onyx dragon's Avatar
Default Automatic with a very specific issue with stalling
Hey all. Not sure where to begin on this. I have a 2001 T/A that is an automatic. It has had the cam, intake manifold, and TB all upgraded. In addition it has a Volant CAI in it. The tune was done by a reputable shop called P-Tuning.
The problem is when I take my foot out of the gas right before the 1-2 shift and it shifts into second, or right after it shifts into second, it will stall, but only when the A/C or defroster is on. If I have the HVAC totally off, it doesn't happen. I've replaced the IAC and it seems to be a bit better, but it still stumbles pretty badly.
To add to this, a couple days ago I got on it, and it downshifted hard, the tires scratched and it acted like it shifted to 4th. I had to let off, then push the gas again to get it to downshift. It was almost like the torque converter locked up, but it is a pretty big RPM drop, more than what should happen from a stock converter locking up.
P-Tuning adjusted the TB a bit, and that helped, but they also raised the rolling idle, which also helped. Both of those were done before the IAC. The rolling idle was really high, and I was getting 11 MPG just driving around normally. I had them drop that down to just a little above normal. I'm not sure where to go from here, if this is something failing in the engine, or if this is a possible torque converter/trans issue.
As stated this has an automatic, but it has no traction control. Thanks for any help you guys can give!
Old Mar 10, 2024 | 06:13 PM
wssix99's Avatar
Save the manuals!
If the car worked well for you for a time and the tuner doesn't see anything that is off, then I would think that would make the torque converter suspect.
Maybe you can start with replacing the transmission fluid?
Old Mar 10, 2024 | 06:38 PM
LilJayV10's Avatar
What type of convertor does it have in it?
Any logs of it doing it?
Old Mar 11, 2024 | 06:13 AM
Fluid looks pretty good, but mileage wise it is time for a change, so I'll do that.
Old Mar 11, 2024 | 06:16 AM
No logs yet, I'm hoping to get some this weekend.
The converter is the factory converter. 75k miles, it sat for about 11-12 years before I got it and needed work to get it running, so it hasn't seen any track time and 99% of the miles have been easy miles for it's life.
