Sponsored by: CARiD
Car pulls to the left
Old Aug 31, 2024 | 05:27 PM
Danimal85's Avatar
Default Car pulls to the left
99 Z28 is pulling to the left when driving. Feel it pull harder at higher speeds. Thinking it's a wheel bearing. Alignment was done not too long ago. Thoughts?
Old Aug 31, 2024 | 06:12 PM
Full Power's Avatar
Originally Posted by Danimal85
. Thoughts?
. Add more AIR to the LEFT front tire ?
. Get a heavier girlfriend to ride on the RIGHT front seat ?
Old Sep 1, 2024 | 06:32 AM
EDS01SS's Avatar
check tire pressure/possible tire damage, get a heat gun and check the rotor temps. could be a sticking caliper, put it on some jack stands and remove the calipers and spin the wheels. is there excessive drag? why was the alignment done and was it it pulling before the alignment?
Old Sep 1, 2024 | 09:31 AM
gjohnsonws6's Avatar
I’ve seen many fresh alignments out of spec over the years. Before you start going in circles I’d take it back for a check and go from there.
Old Sep 2, 2024 | 12:59 AM
01WS6/tamu's Avatar
Take it back and get it checked. If it's in spec more than likely a tire switch the front wheels and see if the pull goes away if it moves or goes away you have your answer
