Coolant Leak Issue
I'm hoping it's just the hoses leaking and there's nothing bigger going on but seeing the coolant like that freaks me out. I looked under the oil cap and everything looks good there. The power steering fluid looked a bit low but was the right colour. Do you guys think I could have a head gasket issue or leaking power steering cooler maybe, or something else? Or if I just replace the hoses and flush everything will be OK?
You think it might be leaking into the coolant? And if so do you think it's related to the big leak I'm having? That one is on the left side of engine and the PS cooler is more to the right.
It looks like you have a stock radiator cap. If so, that's good. Many people have had issues with aftermarket ones.
I would start with a pressure test and make sure your cooling system is holding pressure. (I assume that it is not, which is leading to your boil-over.) Fix that first and then you can solve the other stuff.
In the future, you should plan for:
- Deleting the power steering cooler. (There are many great threads on this here.)
- A full flush of your power steering fluid. (Mandatory when removing the power steering cooler and every few years running without the cooler.)
- A full flush of your coolant. (Not like the "mechanics" do it... Half of the coolant is stored in the block, so you can't flush the system by opening up the radiator.) The radiator and block need to be drained. (There are two plugs on the block that are removed to do this.)
I see that it's an M6 car (based on the radiator), so at least you know that it's not a leaking trans cooler.
How badly did the engine overheat?
I would guess that you either have engine oil or PS contamination in the coolant.
if it's oil contamination would that be a head gasket?
