Sponsored by: CARiD
4th gen Camaro Belts don't lock?
Old Apr 3, 2025 | 04:38 AM
Maxis96's Avatar
Default 4th gen Camaro Belts don't lock?
Hello, i have a 96 Camaro (T-tops) and since i've had it i've never gotten the belt to lock when i pull it.
It still passes the inspection but i'm more worried about safety.
Is there a way to fix them, making them easier to lock?
If i have to replace the belt then how do i get through the roof of the car?
Old Apr 3, 2025 | 07:35 AM
fst100's Avatar
the belt setup in the 4th gen is a pendulum style meaning it doesnt lock like the standard but under extreme tension being pulled it'll work. try and test it
Old Apr 4, 2025 | 08:57 AM
wssix99's Avatar
Save the manuals!
Yes, if you jerk on it really hard and really fast it might lock. In a crash, the pendulum should move and lock the belt.
That being said, dirt and fuzz can gum up that mechanism. I would test both sides of the car and see if the behave differently. If you have a problem, it would typically show up on the driver's side first.
Old Apr 4, 2025 | 10:53 AM
SparkyJJO's Avatar
Compared to some other cars the belt lock on my Camaro isn't as easy to trigger, but I'm ok with that as long as it works, partly because I guess I'm too fast and half the time l lock the belt just trying to put it on half the time
