Sponsored by: CARiD
Can causing engine to stall when braking?
Old Jun 4, 2025 | 09:38 AM
Potatoes9001's Avatar
Default Can causing engine to stall when braking?
Recently purchased a slightly built Z06 and have found that when braking in gear the engine will stall. RPM is set around 850. The car will stop perfectly fine will in neutral. Any ideas of what to do?
Old Jun 4, 2025 | 10:02 AM
Bbknucks's Avatar
Assuming it's an automatic... needs better tuning
BRAF needs attention...easy to do if you have hptuners or something
Old Jun 4, 2025 | 02:25 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I would assume it's a manual based on being a Z06...
