Anyone seen anything like this before!
1999 Camaro z28.
When you start up and let the engine idle all appears fine, it'll rev if you blip the throttle pedal. As soon as you move however the dash starts doing this weird thing (see video), flicking on and off with the dials and warning lights. The engine also feels rough and lumpy when moving and an unwillingness to rev. While moving (about 20mph) it did cut out and stall with a backfire once, although I was only driving it gentle to try and get back home.
If you come to a stop and let the engine idle the dash will return to normal, but as soon as you move again it'll restart the same issue. If you press the clutch pedal while moving and let the revs drop to idle (coasting/free wheeling) the dash pulsing/flickering seems to slow somewhat with a bigger delay. It seems to have some relationship to speed and revs, but not directly so.
Clearly it seems to be some kind of electrical issue. But I've never seen anything like this and have no idea where to start looking. Any help appreciated.
