Sponsored by: CARiD
01 SS Camaro AC Trouble
Old Sep 17, 2025 | 02:27 AM
Glockruger4074's Avatar
Default 01 SS Camaro AC Trouble
I need some help with my ac.. i had a local mechanic install a new ac compressor, condenser, new hot line, and the dryer container that is the low side, sorry cant think of the part. But long story short, it was done right but it had a leak, so after 6 days it blew hot air. Tired of this so called mechanic, I fixed the leak, pulled vacuum for an hour, no leak but now my low side is at a higher pressure then the high side but the compressor clutch is engaged but no cold air at all. Could I please 🙏 get some ideas or if you know the problem, I beg for help.
Old Sep 17, 2025 | 02:40 AM
I need some serious advice. I bought a new ac compressor kit and had it installed by a local mechanic. Long story short it would blow cold but after 6 days it leaked out, so I ended up fixing the leak, put a vacuum on the system, leak was fixed but now my low side is higher then the high side, compressor clutch is engaged but absolutely no cold air coming out. I beg someone to please help me figure this out. Please 🙏
