Sponsored by: CARiD
2003 Silverado 1500hd 6.0 lifter issue
Old Nov 3, 2025 | 12:45 AM
E63Albert's Avatar
Default 2003 Silverado 1500hd 6.0 lifter issue
Got a 2003 Silverado 1500HD 6.0. I just did new lifters, oil pump, and pickup tube with a new O-ring. Truck runs solid but it’s still got a constant ticking sound — sounds just like a lifter tick that never went away.
Oil pressure looks fine on the gauge but I haven’t checked it with a mechanical one yet. Tick doesn’t go away hot or cold, it’s just always there.
I also have 3 broken exhaust bolts on the passenger side and the driver side header gasket is missing that double-sided metal piece, so I’m wondering if that could be what I’m hearing instead of an actual lifter.
Anybody run into this before? Could I have messed up something with the oil pump install or pickup tube, or y’all think it’s just exhaust leaks making noise?
Old Nov 3, 2025 | 07:02 AM
wretched73's Avatar
110% exhaust leak
Old Jan 7, 2026 | 06:21 PM
jetech's Avatar
Veteran: Air Force
really should fix the exhaust leaks. That way you are more likely to be able to discern any abnormal engine noises.
Old Jan 7, 2026 | 10:06 PM
the_merv's Avatar
Veteran: Air Force
How do you take all that apart, and put it back together with broken and missing ****..and you KNOW that...
******* people...................
