Sponsored by: CARiD
TECH 2 Evap Service Bay Test
Old Apr 6, 2026 | 07:02 AM
Ape Man's Avatar
Default TECH 2 Evap Service Bay Test
Hey guys, question if I am running the service bay test with the tech 2 to ready the EVAP monitor set, so I start with car cold or have it up to temp?
can’t seem to find that anywhere, cars currently sitting in garage so would be a cold start, or do I need to get it warm before starting
Old Apr 6, 2026 | 04:34 PM
1FastBrick's Avatar
Scan tool walks you through the process. It supposed to be a cold start. Has you get to certain temp and then gives you a 10 minute/10 mile drive cycle you have to complete. It runs the test at various points. It compares the readings at cold start to the warm and looks to see if they are out side of the range.
Has to be between a certain ambient temp Like 50-85 as well as the tank needs to be between 15% and 85%
If you don't have all the conditions it will abort the test.
Old Apr 6, 2026 | 04:37 PM
1FastBrick's Avatar
Service Bay Test
Description
The EVAP Service Bay Test raises the engine coolant temperature (ECT) threshold so that the temperature sensitive EVAP diagnosis tests can run while in service environments. When the EVAP tests are run the Service Bay Test will indicate a passed or will indicate a specific DTC code has failed. The EVAP Service Bay Test can be used to verify an existing condition and verify that the EVAP system is OK after a repair is completed.
Conditions for Running the Test
Important: The following conditions must be met in order to enable the Service Bay Test.
  • The ignition is ON.
  • The battery voltage is between 9–18 volts.
  • The engine coolant temperature (ECT) is less than 70°C (158°F).
  • The fuel level is between 15–85 percent of capacity.
  • The vehicle speed is less than 4.8 km/h (3 mph).
  • Stored DTCs have been cleared.
Test Procedure
  1. Install a scan tool.
  2. With a scan tool, select the Service Bay Test in the special functions menu.
  3. Follow the instructions on the scan tool.
  4. Continue with the published service manual diagnostic DTC procedure.
Here is what it states about the EVAP Drive Cycle.
EVAP SYSTEM MONITOR DRIVE CYCLE INSTRUCTIONS
·Do not turn off the ignition switch during the test procedure.
·All Readiness codes are cleared when the battery is disconnected or when the ECM/PCM is cleared with the Scan Tool.
·This drive cycle can be used to determine if the Readiness code for this Monitor will run and complete, and if the MIL will remain off after the vehicle is driven.
·Operating Range: Whenever a range of values is provided, try to operate the vehicle in the middle of the range. For example, if the vehicle speed range is from 45-65 mph, operate the vehicle at as close as possible to 55 mph. Or if range for Short Term fuel trim is -20 to +20%; try to operate the engine at 0%.
·Scan Tool Data: There are certain Parameter Identification (PID) values that must be within range before this Monitor will "run". It can be helpful to pull up those PID items on the Scan Tool so an assistant can view them during testing.
Old Apr 6, 2026 | 04:38 PM
1FastBrick's Avatar
Inspection/Maintenance Evaporative Emission System Set
Description
The purpose of this test is to satisfy the enable criteria necessary in order to execute the I/M readiness diagnostics for the EVAP System. The test can be used to set the I/M System Status indicators to YES. Service Bay Tests are included on the scan tool for some systems, depending upon the vehicle make and model. The test is designed to allow the EVAP diagnostic tests to run during service bay conditions. Before you perform either EVAP system test, ensure that the vehicle meets the requirements listed in the Conditions for Running the DTC. Failure to meet the necessary requirements may produce inaccurate test results.
Non Scan Tool Service Bay Test Equipped Vehicles
  • The barometric pressure is more than 75 kPa.
  • The fuel level is between 1/4 and 3/4 full.
  • The battery voltage is between 10–18 volts.
  • The test will initiate only after a cold start. If the following conditions are met, the control module considers the engine to be cold:
    • The engine coolant temperature (ECT) is between 3.75–30°C (39–86°F).
    • The intake air temperature (IAT) is between 3.75–30°C (39–86°F).
    • The difference between the ECT and the IAT is less than 8°C (14°F).
  • The BARO is more than 75 kPa.
  • The ECT is less than 80°C (176°F).
Diagnostic Aids
Extreme high or low ambient temperatures may prevent the EVAP System Tests from initiating. Inspecting the system prior to running the EVAP Service Bay Test may prevent having to repeat the test. A loose fuel cap may cause a Service Bay Test to abort or to fail, and prevent the I/M System Status from updating. A failed or aborted test will require the vehicle to cool down in order to meet the enable criteria to run another test.
The I/M System Status does not indicate whether the test has passed or failed, only that a decision was made. When all of the diagnostics for a specific system have run and passed, the I/M System Status will update to YES. If a test for a specific system has failed, the I/M System Status will update to YES, indicating a determination was made, even if all of the required tests have not run. When a failure occurs, the Emission Related DTC portion of the I/M System Status display will indicate the malfunction indicator lamp (MIL) is requested. The I/M System Status also registers the number of diagnostic trouble codes (DTCs).
The first failure of a type B DTC does not constitute a final determination of pass or fail, and will not update the I/M System Status to YES. A second trip is required, and all the conditions to run must be met in order for the test to run again. These conditions may include a partial to complete engine cool down.
The I/M System Status will update only when an emission related DTC fails the second time, or when all of the tests pass.
If there is an impending failure, the system may require more time to run the diagnostic than was allotted in the set procedure. If the test does not run after numerous attempts and no DTC is set, review the appropriate scan tool data list and the service information for an indication of why the test does not complete. Some tests may abort due to changes in the conditions while the test is running. For example, changes in engine load, such as a cooling fan or an A/C compressor clutch turning ON, may cause the test to abort.
If a diagnostic test is difficult to run, maintain necessary enable conditions until the system status updates to YES.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
  1. Before you perform this test, you must perform the I/M System Check. Failure to do so may result in difficulty updating the status to YES.
  1. This step is to determine whether or not the EVAP System Test has passed. If the system is operating correctly, the scan tool indicates that the system has passed and the I/M System Status updates to YES. If the EVAP Service Bay Test aborts because of lost enable conditions, the test can be repeated once the enable criteria is met.
  1. A failed DTC during the EVAP Service Bay Test may not appear in the DTC Information display on some vehicles. The Service Bay Test displays an indication of which test failed as a directive to the appropriate service information. Some vehicles will display the test as aborted and the first failure of type B DTC appears in the DTC Information.
  1. The EVAP System Test usually begins with an engine coolant temperature of approximately 4°C (39°F). The vehicle should be operated moderately until this temperature is reached. Use the scan tool in order to monitor the engine coolant temperature.
  1. This step is to identify a first failure of a type B DTC. A DTC only appears on the I/M System Status display when the DTC becomes a MIL-illuminating DTC. This occurs on the second failure of a type B DTC. A first failure of a type B DTC will not allow the I/M System Status to update to YES. Refer to Diagnostic Aids.
  1. This step helps to identify any unique or unusual criteria that are required to run the diagnostic test if the universal set procedure does not. This information is located in the service information under Conditions for Running the DTC.
  1. The I/M System Status only reports on whether or not a diagnostic has run, not the outcome. If any emissions-related DTC sets after the tests are complete, the DTC will require diagnosis.
Old Apr 6, 2026 | 08:52 PM
Ape Man's Avatar
Thanks! I heard in 02 cars didn’t need the road test part
Old Apr 6, 2026 | 09:04 PM
1FastBrick's Avatar
I don't have one so I can not comment on that. How ever every other car or truck that I have run the test on requires that drive cycle.
As for the data I Posted above, I specifically looked up a 2002 Camaro SS.
Let us know How it goes!
