Sponsored by: CARiD
Normal oil pressure?
Old Sep 7, 2004 | 09:18 AM
SSCamaro99_3's Avatar
60+ psi at cold idle, 42 psi at hot idle, over 60 psi from 4000 rpms on up.
Old Sep 7, 2004 | 12:20 PM
Scalpel's Avatar
Originally Posted by Ferocity02
I don't think 7psi/1000 rpm makes sense. That would be like 5 psi at idle... I assume that only means for above idle pressure... Mine is about 50 psi idle, 80 at WOT.
That's what GM dictates in the service manual, 7 PSI per 1000 RPM, so at 7000 RPM you should have at least 49 PSI.
Old Sep 8, 2004 | 06:42 PM
pewterbirdls1's Avatar
i live in florida..my car runs at 60 psi or so cold and a 35 psi or a below when warm.. Ive always used Mobile 1 syn 10w30 since i owned the car (3yrs).When it is real hot i have infamous ticking sound..Is it ok to use 10w-40 syn catrol ? do u think this would help with noise and oil pressure??>My car has about 49000 miles, stock except for loudmouth exhaust and K@N filter........
Old Sep 8, 2004 | 06:48 PM
Cerebrex's Avatar
Castrol is a piece of **** when it comes to synthetics. All but mobil 1 aren't truly synthetic.
Old Sep 8, 2004 | 07:10 PM
What about 15w mobil 1 ?or what full syn would u suggest?
Old Sep 8, 2004 | 07:29 PM
Danny2tek's Avatar
same here
Old Sep 8, 2004 | 07:41 PM
bill99hawk's Avatar
Me too! I added about 2.5 quarts of Mobil w50 oil to my 5w30 and the valvetrain sounds smoother and more quiet.
Old Sep 8, 2004 | 07:42 PM
Cerebrex's Avatar
I'd stick to Mobile 1. If you are getting a tick, that can't be good. Are you in a 98? Sounds like your oil pump is going to ****. Has it always been like that?
Old Sep 9, 2004 | 11:26 PM
BLU-BY-U's Avatar
my stock oil pump took a dump. It was showing about 21psi idle hot, and 54 at redline (6500 ls6). I had it replaced with a brand new, ported pump and I'm getting 52psi idle and over 80 at WOT (pegging analog guage and showing 83 on the digital).
can you have too much psi?? oil is redline 1030 and filter is a k&n
Old Sep 10, 2004 | 01:45 AM
Cerebrex's Avatar
I don't think their is such a thing as too much psi, unless the numbers are ridiculously high.
Old Sep 10, 2004 | 11:32 AM
Scalpel's Avatar
If you have too much oil psi you can pop out the oil galley plugs and thus have significantly decreased oil pressure.
Old Sep 10, 2004 | 01:33 PM
  #32
BLU-BY-U's Avatar
I was afraid of that
ok, so what's "too much"? this is on a basically stock LS6 block with around 23K miles on it.
