Power steering leaks out?
Is there any issues with the caps, or with the fluid overheating or sloshing around too much and make it force out? Would hard lefting/righting in the AX make it boil? I have no idea what to do.
Any suggestions, theories, tips, or links greatly appreciated!
Go to Walgreens and get a package of hair scrunchies ... small enough to fit snuggly around the neck of the reservoir.
Install, replace cap ... problem solved.
When AXing or on a road course, this is a very common problem. High RPM will heat up the fluid and it expands and pukes out the cap. I keep several clean scrunchies in my tool box.
I typically run my fluid at the "ADD" mark and no higher, as well.
And a synthetic fluid will make a difference
