Sponsored by: CARiD
Bad battery or other?
Old Nov 2, 2004 | 05:04 PM
WS6_Dude's Avatar
Default Bad battery or other?
Quick question... (already searched, but still have question)
I turn the key, I hear the fuel pump start, then I hear ONE click then nothing.
It is not VATS (not getting security light). The voltage starts out around 11 and quickly drops after I turn the key.
Is this the battery? The battery is just a little over a year old. It was driven 4-5 hours daily in stop and go traffic around Wash DC this summer, but for the past two months it has only been driven for short periods on weekends. Is it common for a battery to die that quickly under those conditions?
Thanks a lot for the help.
Doug
Old Nov 2, 2004 | 06:06 PM
DARK AGE 53's Avatar
Being it's election day I'd vote it's the battery, starting out at 11 volts isn't good. It really doesn't matter how old the battery is, I've seen them die sooner and others that go seven years before they give up....head to AutoZone and have them check it out ( around here there no charge to check the battery ).
Al
Old Nov 2, 2004 | 06:25 PM
Z28Venom's Avatar
Take the battery and have it tested at your local parts store. It'll more than likely be a crapped out battery.. Time for an Optima..
Old Nov 3, 2004 | 08:16 PM
cueball's Avatar
yeah sounds like the batt.
optimas are awsome.
i have seen a lot of the ac delco batts. go bad.
good luck man.
Old Nov 3, 2004 | 08:23 PM
WS6_Dude's Avatar
Thanks guys - you were right. It is the battery. I jumped it this afternoon and it started right up. But I probably need to look at getting a replacement for it with winter coming. So Optima is a good brand to go with?
Old Nov 3, 2004 | 08:53 PM
A battery worth considering is the AutoZone Duralast Gold series battery, it has a 8 year warranty and the first 3 years has a 100% free replacement warranty.
