opti go boom now missing
and ever since i changed plugs and wires my abs inop light comes on...any help would be gr8ly appreciated... Number one can be caused by a dirty, clogged, or inoperative fuel injector; air leaks; low fuel pressure due to weak fuel pump; a restricted fuel filter; or a leak fuel pressure regulator. Also, a leaky EGR valve can cause the same problems as an air leak.
Number two can be caused by a burned exhaust valve or a blown head gasket.
