Trip odometer resets on startup sometimes
After searching on my problem and determining that it is probably the battery / connection, not a reaplcemewnt of the display (I hope). Since this problem only occurs if the car sits for awhile (20 minutes or more, sometimes less)
I know there was a service bulletin about this. I would likt o know if replacing the battery alone has solved this for people. I am having a hard time figuring out how the battery is the sole cause for this problem.
Also if I need the gauges replaced how much is that gonna run? I assume I have to order from GM with mileage inserted.
Any help is greatly appreciated.
If for some reason it is the instrument cluster. You just order one from GM ( $$$ ) or check out eBay for a nice used one. Mileage is NOT stored in the instrument cluster. It is stored separately in a computer module (don't remember the proper name), and is difficult to change or roll back. So no worries there
Thanks for the help!
GM have issued a service bulletin for this (99-08-49-009).
I have a .jpg of the bulletin here but it's too large to download.
So if I put another cluster in the correct mileage on the vehicle will be shown on the gauges. Just wanted to know before i decide how to get mine fixed.
