Sponsored by: CARiD
gas smell?
Old Feb 8, 2005 | 06:30 PM
Bill's 02 Z-28 SS's Avatar
Default gas smell?
Hi folks
97 Z-28 LT1/M6 (my daily ride) - in the morning when I start and drive the car about a 1 mile, stop at a red light I get a strong smell of gas. I replaced the gas cap but still have. The wild part of this is, after that I never smell until the next day. What could this be?
thanks
Bill
Old Feb 8, 2005 | 06:47 PM
396D1SS's Avatar
maybe a leakey injector...
Old Feb 8, 2005 | 07:03 PM
BizZzatch350's Avatar
Moderator
Any service engine lights on?
Old Feb 8, 2005 | 07:05 PM
SAPPER's Avatar
Or the the supply/ return lines to the fuel rails. If you have taken them off at all, the O-rings might need replacing
Old Feb 9, 2005 | 06:23 AM
No Service Engine light or codes - only happens in the morning.
Bill
Old Feb 9, 2005 | 06:24 AM
Have not taken the any fuel lines a part - it just happens in the morning, once the car is warmed up, no smell at all.
Bill
Old Feb 9, 2005 | 08:33 AM
SAPPER's Avatar
The issue might bee that while the car is off for a long period (over night), the pressure in the system will drop and allowing an o-ring somewhere to relax and allow gas to seep out. As soon as the key is turned on, the system pressurizes, the o-ring seals, but there is gas on the engine somewhere and eventually it burns off and the smell goes away. You'll just have to take a morning to get in there and feel around before starting the car. Preferably a day off. Check everything, lines, pressure regulator, filter under the car, injectors, even the tank and lines.
Old Feb 9, 2005 | 09:02 AM
Hi SAPPER
I will gave it a try and complete checkout the car for a gas leak. Does these year car have a re-circulator system for gas fumes? Does it have a Canister?
Thanks
Bill
Old Feb 9, 2005 | 09:11 AM
SAPPER's Avatar
The fuel system has a feed and return line. any excess fuel or vapor is returned to the tank. It is a pressurized system.
Old Feb 9, 2005 | 10:53 AM
Hi Sapper
Thanks, I was not sure.
Bill
