draw on battery?
Once you find out what kind of draw is on the battery, thus verifying that this isn't a charging system problem, you can then start pulling fuses one-at-a-time as you watch the DVOM. When the amperage draw decreases, you've found the trouble circuit.
I believe the goal is to hit roughly 30-50 milliamps. Using this method, I found out my car has a 75 mA draw, because the idiot that installed my sub/amp didn't use a switched power source. If I unplug the fuse for the sub/amp, the amperage draw will drop to about 35 mA (right where I want it). I'll have to wire in a relay for it now.
As for another example, my roommate's car has a huge draw coming from his alarm. He's well into the 100+ mA range. Talk about a pathetic aftermarket alarm system. Its anti-theft feature is to drain the battery so nobody can drive away with it...
